Introducción
The first step to every electronic repair is to turn it off and back on again. But, this is only possible if your power button works.
If it’s broken, follow this guide to replace the power button on your Kindle Fire HDX 7” tablet.
Qué necesitas
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
