Saltar al contenido principal
Qué necesitas
Este desmontaje no es una guía de reparación. Para reparar tu Kindle Fire HD 6, utiliza nuestros manuales de servicio .
  1. Kindle Fire HD 6 Teardown, Kindle Fire HD 6 Teardown: paso 1, imagen 1 de 1
    • One hundred dollars. One Benjamin. A single C-note. That's the cost of a Amazon's New Kindle Fire HD 6. Let's see what your not-so-hard-earned cash buys you:
    • 6" high definition touchscreen with 1280 x 800 resolution at 252 ppi
    • Quad-Core processor with two cores running at 1.5 GHz and two cores at 1.2 GHz
    • 1 GB of RAM
    • 8 GB (4.5 GB available to user) or 16 GB (11.6 GB available to user) of internal storage
    • 802.11b, 802.11g, or 802.11n Single-antenna Wi-Fi + Accelerometer + Gyroscope + Bluetooth
    • VGA Front-facing Camera + 2.0 MP Rear-facing HD camera
  2. Kindle Fire HD 6 Teardown: paso 2, imagen 1 de 3 Kindle Fire HD 6 Teardown: paso 2, imagen 2 de 3 Kindle Fire HD 6 Teardown: paso 2, imagen 3 de 3
    • Good news, everyone! You won't need anything fancier than an opening pick to crack this case. Plastic clips and no adhesive secure the panel.
    • This looks familiar. It seems the Fire HD 6 is just a small Kindle Fire.
    • Already a very simple device, the Fire has undergone some serious streamlining internally (not to mention shrinking externally).
    • It looks to us like the motherboard, rear camera, battery, and speaker are all clearly available for easy removal...
  3. Kindle Fire HD 6 Teardown: paso 3, imagen 1 de 3 Kindle Fire HD 6 Teardown: paso 3, imagen 2 de 3 Kindle Fire HD 6 Teardown: paso 3, imagen 3 de 3
    • Or so we thought. The battery, while up on top and otherwise ready to roll, is suffering from separation anxiety.
    • Dear Amazon, can you please tone down the Kindle battery glue? Thank you.
    • Even with our plastic card, we had to use excessive force to pry the battery out.
    • The 3.7 V, 3400 mAh (12.6 Wh) Lithium-ion Polymer battery in the Kindle Fire HD 6 is pretty hefty at 60 grams—about one fifth of the total weight of the Fire.
    • Amazon promises about 8 hours of use, but warns that "results may vary."
    • For the record, the HDX 7" clocks in at 17.29 Wh and the original 7" Fire tablet had a 16.28 Wh capacity.
  4. Kindle Fire HD 6 Teardown: paso 4, imagen 1 de 3 Kindle Fire HD 6 Teardown: paso 4, imagen 2 de 3 Kindle Fire HD 6 Teardown: paso 4, imagen 3 de 3
    • Moving right along on the "removing modular components" train, we pull out the speaker, rear-facing camera, and finally (after all of that effort) the motherboard.
    • The 2.0 MP rear-facing camera is...well...a camera.
    • Which is great if you ever wanted 2005 flip-phone photography in a new unwieldy format.
    • According to Amazon, the rear-facing camera is capable of taking high-resolution photos (including panorama and HDR photos) and capturing 1080p HD video.
  5. Kindle Fire HD 6 Teardown: paso 5, imagen 1 de 1
    • These are the ICs that ignite the Kindle Fire HD 6:
    • SK Hynix H5TC4G63AFR 4 Gb (512 MB) DDR3L SDRAM (512 MB x 2 = 1 GB)
    • Toshiba THGBMBG6D1KBAIL 8 GB e-MMC NAND Flash
    • MediaTek MT8135V Applications Processor
    • MediaTek MT6397A 1425-ANAH EC4 AW80H
    • MediaTek MT6628TP Wi-Fi/Bluetooth Controller
    • SlimPort ANX3618 SlimPort Connectivity IC
    • Cypress Semiconductor CY8CTMA4 63-56LQI 1419 F 04 CYP620476
  6. Kindle Fire HD 6 Teardown: paso 6, imagen 1 de 1
    • A few straggler ICs reside on the back side of the motherboard:
    • Maxim Integrated MAX97236 Audio Amplifier with Jack Detection
    • M651 X171C1 L146
    • Novatek NT50357 1422-AD D7MN91
  7. Kindle Fire HD 6 Teardown: paso 7, imagen 1 de 2 Kindle Fire HD 6 Teardown: paso 7, imagen 2 de 2
    • Look ma, no optical adhesive! It's been a while since we've seen a tablet display come apart into non-fused glass and display components.
    • Definitely a design carryover from the original Fire.
    • The 6 inch, 1280 x 800 pixels (252 ppi) display is provided by LG Display.
    • The display glass assembly contains the digitizer and the VGA front-facing camera.
  8. Kindle Fire HD 6 Teardown: paso 8, imagen 1 de 2 Kindle Fire HD 6 Teardown: paso 8, imagen 2 de 2
    • Fire HD 6 Repairability Score: 8 out of 10 (10 is easiest to repair).
    • The rear case is very easy to open, granting trouble-free access to the internals.
    • All the fasteners found inside are T5 Torx screws—one non-proprietary screwdriver is all you need.
    • Simplistic design and limited functionality means fewer components and less headache for disassembly.
    • Battery adhesive is much stronger than necessary, which makes disassembly hazardous.
    • The glass panel is fused to the front plastic frame, meaning a heat gun is required for replacing cracked glass (or you have to replace both components together).
    • Lack of available replacement parts has limited repair options in other Kindle models. We can only hope this model doesn't share the same fate.
8 comentarios
Simplistic refers to treating somthing as much simpler than it is.
In this case, calling partial disassembly into a few major subassembles, one of which contains more than 95% of the content of the device, a teardown, is a simplistic understanding of what a teardown is.
The design is clean and straight forward, but not simple, except perhaps to someone would would regard an automobile engine/transmission assembly as a component to be replaced rather than repaired.
gdrgry34fsdf324 - Contestar
Hey guys, does anyone know where I can purchase a glass replacement or the entire front glass housing? My son dropped it while coming out of the car, and the entire glass shattered. Thanks in advance :)
Anibal Alanis - Contestar
hey Anibal Alanis, you can buy it on Amazon or online shopping, check on google
http://hargasmartphone.id/harga-apple-ip...
irwansyah10 -
Nobody has these replacement screens. Amazon suggested just to buy a new one, of course! maybe in a few months, China will start cranking them out and I can finally fix my son's unit without spending $100
christy cunningham - Contestar
I don't know what if anything you did about this , as your post is 11 months old at this time, but I bought this same device from a neighbor for $20. It has a cracked screen. Cost to replace it? $100
cackalackyhacky -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 33,975
