Saltar al contenido principal
Kindle 7th Generation Back Panel Replacement
Qué necesitas
  1. Kindle 7th Generation Back Panel Replacement, Front Panel: paso 1, imagen 1 de 2 Kindle 7th Generation Back Panel Replacement, Front Panel: paso 1, imagen 2 de 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Back Panel Replacement: paso 2, imagen 1 de 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Kindle 7th Generation Back Panel Replacement, Back Panel: paso 3, imagen 1 de 2 Kindle 7th Generation Back Panel Replacement, Back Panel: paso 3, imagen 2 de 2
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
  4. Kindle 7th Generation Back Panel Replacement: paso 4, imagen 1 de 1
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
Conclusión
4 personas más completaron esta guía.
Abby Roulier
Miembro Desde 02/08/15
966 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-28, Amido Winter 2015 Miembro de Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 54
Todo El Tiempo: 4,843
