Saltar al contenido principal
Battery Replacement for the Kindle 4
Qué necesitas
  1. Battery Replacement for the Kindle 4, Opening the case: paso 1, imagen 1 de 2 Battery Replacement for the Kindle 4, Opening the case: paso 1, imagen 2 de 2
    • Use plastic opening tools to pry open the case starting on the long side. The cover has a total of 8 clips, 4 of which (located on the long sides) are designed so they will be damaged when the device is opened.
  2. Battery Replacement for the Kindle 4, Loosening the adhesive: paso 2, imagen 1 de 1
    • After prying open 3 sides of the cover, it is still attached to the aluminium cover by double-sided adhesive tape. Use a screwdriver to create a small gap and use the scalpel to cut the adhesive. Alternatively you can losen the adhesive with a heat gun.
  3. Battery Replacement for the Kindle 4, Remove the case cover: paso 3, imagen 1 de 1
    • After loosening the adhesive, the case cover can be easily removed.
  4. Battery Replacement for the Kindle 4, Remove the battery cover: paso 4, imagen 1 de 1
    • Remove the two TX5 screws from the battery cover.
  5. Battery Replacement for the Kindle 4, Remove any adhesive residue: paso 5, imagen 1 de 1
    • Remove any adhesive residue from the battery cover and the housing cover with a scalpel / rubbing alcohol.
  6. Battery Replacement for the Kindle 4, Disconnect the battery: paso 6, imagen 1 de 1
    • Then carefully disconnect the battery flex cable, ensuring that the contacts are not being short-circuited.
  7. Battery Replacement for the Kindle 4, Remove the battery: paso 7, imagen 1 de 1
    • The battery is adhered to the housing, it takes some force to remove it. Avoid puncturing of the battery as it could catch fire and/or explode! Dispose of the old battery properly.
  8. Battery Replacement for the Kindle 4, Insert new battery: paso 8, imagen 1 de 1
    • The new battery can be fastened through the remaining adhesive residue. Reconnect the flex cable of the new battery, making sure that the contacts are not short-circuited.
  9. Battery Replacement for the Kindle 4, Control function: paso 9, imagen 1 de 1
    • The display should indicate a empty battery.
    • Before further assembly, the battery should be fully charged and it should be checked whether the device terminates the charging process when the battery is fully charged. If this is not the case, the new battery could be destroyed by the device.
    • Monitor the initial charge and carry it out in a place where there are no flammable objects.
  10. Battery Replacement for the Kindle 4, Secure the battery cover: paso 10, imagen 1 de 1
    • Secure the battery cover with the two TX 5 screws. Ensure a good fit of the back cover with a few strips of double-sided tape. Limit the amount of tape so as not to hinder future disassembly.
  11. Battery Replacement for the Kindle 4, Finish the reassembly: paso 11, imagen 1 de 1
    • The rear cover will still fit well and tight despite the four missing fastenings.
Conclusión
12 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Sigi Gruber
Miembro Desde 11/28/18
583 Reputación
1 Guía escrita
2 comentarios
Es sollte m.E. noch ergänzt werden, dass der Deckel an den schmalen Seiten mit je zwei Laschen gesteckt ist. Um den Deckel zu lösen, muss man, nachdem die langen Seiten wie beschrieben geöffnet wurden, ihn etwas nach außen wölben: Man zieht dazu die schmalen Seiten in Richtung der Gehäusemitte, so dass man die Laschen herausziehen kann.
Martin Dauskardt - Contestar
By far the worst part is the battery cover is welded to the back of the case with gluonium which cannot be removed with anythhng but gamma rays and kryptonite, so as the guide says,, long thin knife is what you need. The battery is glued in the same but you don’t care so much at this point :-) See step 3, the tabs top and bottom, you remove the cover by flexing it away from the frame at about the mid point.
Time and patience, gently, gently teasy monkey…
Tosspot - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 64
Ultimos 30 días: 252
Todo El Tiempo: 10,135
