Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Kindle 1st Generation Keyboard/Buttons Replacement
Qué necesitas
  1. Kindle 1st Generation Keyboard/Buttons Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the grey plastic cover laterally off the back of the device.
    Pregunta a FixBot
    Agregar Comentario
  2. Kindle 1st Generation Keyboard/Buttons Replacement: paso 2, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to lift the battery on the side closest to the edge of the device.
    • Unplug the battery from the device by pinching the white connector and pulling.
    • Do not yank the battery or try to disconnect the battery by pulling the wires.
    Pregunta a FixBot
    Agregar Comentario
  3. Kindle 1st Generation Keyboard/Buttons Replacement, SD Card Reader: paso 3, imagen 1 de 1
    • Unscrew eight (8) Phillips #00 screws (3 mm).
    Pregunta a FixBot
    Agregar Comentario
  4. Kindle 1st Generation Keyboard/Buttons Replacement: paso 4, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 4, imagen 2 de 2
    • Start at one side of the device. Use a plastic opening tool to separate the casing of the device. Slowly work your way around the entire device.
    • Avoid prying between the buttons and the device. This could cause damage to the buttons.
    Pregunta a FixBot
    Agregar Comentario
  5. Kindle 1st Generation Keyboard/Buttons Replacement: paso 5, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 5, imagen 2 de 2
    • Unscrew the two (2) Phillips #00 screws (3 mm) which fasten the metal casing shield.
    • Slowly remove the metal casing shield by lifting it and carefully peeling up the tape.
    Pregunta a FixBot
    Agregar Comentario
  6. Kindle 1st Generation Keyboard/Buttons Replacement: paso 6, imagen 1 de 1
    • Remove the four (4) Phillips #00 screws (3 mm) which fasten the SD Card Reader.
    Pregunta a FixBot
    Agregar Comentario
  7. Kindle 1st Generation Keyboard/Buttons Replacement: paso 7, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 7, imagen 2 de 2
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with a spudger.
    • The flap is connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Carefully lift the SD Card Reader vertically from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  8. Kindle 1st Generation Keyboard/Buttons Replacement, Page Turner Keys: paso 8, imagen 1 de 1
    • Remove the two (2) Phillips #00 screws (3 mm) connecting the ON/OFF Power and Wifi Switches.
    Pregunta a FixBot
    Agregar Comentario
  9. Kindle 1st Generation Keyboard/Buttons Replacement: paso 9, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 9, imagen 2 de 2
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the pointed-end of the spudger.
    • Carefully lift the ON/OFF Power and Wifi Switches vertically from the device motherboard.
    Pregunta a FixBot
    Agregar Comentario
  10. Kindle 1st Generation Keyboard/Buttons Replacement: paso 10, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 10, imagen 2 de 2
    • Use a spudger to remove the Wifi antenna from the device by carefully prying it up off the casing.
    • The Wifi antenna is attached to the device by a mild adhesive. Once the antenna is free from the adhesive, set the antenna off to the side.
    • Do not try to detach the antenna from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  11. Kindle 1st Generation Keyboard/Buttons Replacement: paso 11, imagen 1 de 3 Kindle 1st Generation Keyboard/Buttons Replacement: paso 11, imagen 2 de 3 Kindle 1st Generation Keyboard/Buttons Replacement: paso 11, imagen 3 de 3
    • Unscrew the two (2) Phillips #00 screws (3 mm) attaching the scroll bar.
    • Use a spudger to lift the flap vertically in the second image to release the scroll bar from the motherboard.
    • Do not pull the scroll bar off the device. Simply flip it around so it is out of the way for further disassembly, as seen in the third image.
    Pregunta a FixBot
    Agregar Comentario
  12. Kindle 1st Generation Keyboard/Buttons Replacement: paso 12, imagen 1 de 3 Kindle 1st Generation Keyboard/Buttons Replacement: paso 12, imagen 2 de 3 Kindle 1st Generation Keyboard/Buttons Replacement: paso 12, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Lift the flap attaching the blue and white ribbon cable to the motherboard by lifting it vertically with the spudger.
    • Lift the flap with the pointed-end of the spudger to detach the ribbon cable indicated in the second image.
    • The flaps are connected via a hinge. Once you lift the flap, it will stay up and the cable will be lose. Remember to snap it back down during reassembly.
    • Use tweezers to pull the ribbon cable in the third image laterally to detach it.
    Pregunta a FixBot
    Agregar Comentario
  13. Kindle 1st Generation Keyboard/Buttons Replacement: paso 13, imagen 1 de 1
    • Detach the cable by pulling laterally with tweezers or your fingertips. Do this by grasping the edges of the white connector and pulling laterally.
    • Grasp the end of the cable with tweezers or your fingertips and pull upwards to detach it from the motherboard.
    • Do not grasp either cable by the wires and attempt to pull them.
    Pregunta a FixBot
    Agregar Comentario
  14. Kindle 1st Generation Keyboard/Buttons Replacement: paso 14, imagen 1 de 3 Kindle 1st Generation Keyboard/Buttons Replacement: paso 14, imagen 2 de 3 Kindle 1st Generation Keyboard/Buttons Replacement: paso 14, imagen 3 de 3
    • Remove the two (2) Phillips #00 screws (3 mm) which attach the motherboard to the front casing.
    • Carefully lift the motherboard off.
    • The piece marked in the third image may be loose and fall out freely. If it does not fall off, use your fingers or a plastic opening tool to snap it off. Make sure to place it under the motherboard during reassembly, as found in the image.
    Pregunta a FixBot
    Agregar Comentario
  15. Kindle 1st Generation Keyboard/Buttons Replacement: paso 15, imagen 1 de 1
    • Remove the seven (7) Phillips #00 screws (3 mm) remaining on the frame.
    • The orange-marked metal piece is only held down by a screw and will become loose. Make sure to re-position it during assembly.
    Pregunta a FixBot
    Agregar Comentario
  16. Kindle 1st Generation Keyboard/Buttons Replacement: paso 16, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 16, imagen 2 de 2
    • Press down firmly on the two white tabs, behind the large 'NEXT PAGE' button with the spudger. This will unsnap the front casing from the rest of the device.
    • The front case will begin to come loose. Do not try to pull it off.
    • Slide out the large 'NEXT PAGE' button laterally away from the keyboard.
    Pregunta a FixBot
    Agregar Comentario
  17. Kindle 1st Generation Keyboard/Buttons Replacement: paso 17, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 17, imagen 2 de 2
    • Slightly lift the top corner of the panel.
    • Slide the 'PREV PAGE' button out laterally towards the top corner.
    Pregunta a FixBot
    Agregar Comentario
  18. Kindle 1st Generation Keyboard/Buttons Replacement: paso 18, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 18, imagen 2 de 2
    • Slide out the small 'NEXT PAGE' button laterally towards the keyboard.
    Pregunta a FixBot
    Agregar Comentario
  19. Kindle 1st Generation Keyboard/Buttons Replacement: paso 19, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement: paso 19, imagen 2 de 2
    • Slide out the small 'BACK' button laterally towards the keyboard.
    Pregunta a FixBot
    Agregar Comentario
  20. Kindle 1st Generation Keyboard/Buttons Replacement, Keyboard/Buttons: paso 20, imagen 1 de 2 Kindle 1st Generation Keyboard/Buttons Replacement, Keyboard/Buttons: paso 20, imagen 2 de 2
    • The keyboard and the blue and white ribbon cable will slide out horizontally from behind the frame.
    • The rubber key pads will slide out from behind the frame.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
1Guía Comentario
Where do you get a replacement controller wheel/button. This is what failed on my 1st gen kindle.
Joyce stevenson - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 52
Todo El Tiempo: 2,171
