Saltar al contenido principal
Kids Digital Watch Battery Replacement
Qué necesitas
  1. Kids Digital Watch Battery Replacement, Remove Watch Bands: paso 1, imagen 1 de 2 Kids Digital Watch Battery Replacement, Remove Watch Bands: paso 1, imagen 2 de 2
    • Using a twisting and pulling motion, remove the straps from the watch.
  2. Kids Digital Watch Battery Replacement, Unscrew Backplate: paso 2, imagen 1 de 1
    • Remove the four (4) screws on the backside of the watch with the small Philips head screwdriver.
  3. Kids Digital Watch Battery Replacement, Remove Backplate: paso 3, imagen 1 de 1
    • Remove the backplate carefully using your hands.
  4. Kids Digital Watch Battery Replacement, Remove Circuit Protector Plate: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Remove using tweezers the circuit protector plate that is uncovered once the backplate is removed.
  5. Kids Digital Watch Battery Replacement, Removing Screw Near the Blue Component: paso 5, imagen 1 de 2 Kids Digital Watch Battery Replacement, Removing Screw Near the Blue Component: paso 5, imagen 2 de 2
    • With the tiny Philips head screwdriver, unscrew and remove the screw closest to the blue component.
  6. Kids Digital Watch Battery Replacement, Removing Screw Near the Yellow Component: paso 6, imagen 1 de 1
    • Now remove the screw on the other side of the battery near the yellow circuit component.
  7. Kids Digital Watch Battery Replacement, Remove the Battery Protector Plate: paso 7, imagen 1 de 2 Kids Digital Watch Battery Replacement, Remove the Battery Protector Plate: paso 7, imagen 2 de 2
    • Using tweezers carefully remove the battery protector plate.
  8. Kids Digital Watch Battery Replacement, Remove Battery: paso 8, imagen 1 de 1
    • Remove the old battery from your watch.
  9. Kids Digital Watch Battery Replacement, Insert New Battery: paso 9, imagen 1 de 1
    • Insert your new battery onto the circular component with your tweezers.
    • Ensure the positive and negative sides of your battery are oriented correctly.
Conclusión
Una persona más ha completado esta guía.
Amelia S
Miembro Desde 03/14/23
194 Reputación
1 Guía escrita
Equipo
ENGR_COMM_FIXERS Miembro de ENGR_COMM_FIXERS
Community
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 66
Todo El Tiempo: 710
