Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide explains how to replace the internal chip on the Kid Galaxy Morphibians Explorer Controller.
Partes
No se especificaron partes.
  1. Turn the controller over to the backside and locate the battery cover screw.
    • Turn the controller over to the backside and locate the battery cover screw.
  2. The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
    • The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
  3. Once the screw is removed lift the battery cover up from the controller.
    • Once the screw is removed lift the battery cover up from the controller.
  4. Remove the 2 AA batteries.
    • Remove the 2 AA batteries.
  5. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  6. Remove both 6.0mm Phillips #1 screws holding the D-pads in place.
    • Remove both 6.0mm Phillips #1 screws holding the D-pads in place.
  7. Insert wisdom here.
    • Insert wisdom here.
  8. Remove the six  8.1 Phillips #1 screws.
    • Remove the six 8.1 Phillips #1 screws.
  9. Lift the antenna holder away from the controller towards the top of the antenna.
    • Lift the antenna holder away from the controller towards the top of the antenna.
  10. Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
    • Before you separate both halves of the controller make sure the battery holder is facing you so the D-pads stay in place.
    • Separate both halves of the controller.
  11. Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
    • Remove the 7.9 Phillips #1 screw that holds both the antenna and the internal chip.
  12. Remove the internal chip by pulling it away from the controller.
    • Remove the internal chip by pulling it away from the controller.
    • Remove both the positive(red wire) and negative(black wire) from the battery terminals.
    • Reverse the steps to put everything back together.
Conclusión
Equipo
USF Tampa, Team 1-2, Hickman Fall 2014 Miembro de USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 123
