Saltar al contenido principal
Kid Galaxy Morphibians Explorer Controller Battery Replacement
Qué necesitas
  1. Kid Galaxy Morphibians Explorer Controller Battery Replacement, Batteries: paso 1, imagen 1 de 1
    • Turn the controller over to the backside and locate the battery cover screw.
  2. Kid Galaxy Morphibians Explorer Controller Battery Replacement: paso 2, imagen 1 de 1
    • The battery cover 8.0mm Phillips #2 screw is on the bottom left handle. There is a plastic washer holding the screw to the cover, so completely loosen the screw, but do not remove.
  3. Kid Galaxy Morphibians Explorer Controller Battery Replacement: paso 3, imagen 1 de 1
    • Once the screw is removed lift the battery cover up from the controller.
  4. Kid Galaxy Morphibians Explorer Controller Battery Replacement: paso 4, imagen 1 de 1
    • Remove the 2 AA batteries.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 1-2, Hickman Fall 2014 Miembro de USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 183
