Introducción
If your Kid Galaxy Morphibians Explorer controller (Model number: QEA-E097-49R) is not working, it probably just requires a quick battery replacement. This guide will inform users on how to replace their controller battery. The only required tool is a Phillips #2 screwdriver.
Be aware of possible battery corrosion. If a battery has corroded, or leaked out any battery acid, carefully remove the battery and wipe all remaining acid off of the toy before replacing the battery.
Qué necesitas
Turn the controller over to the backside and locate the battery cover screw.
Una persona más ha completado esta guía.
