Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
There are only a few steps that you need to take in order to replace the batteries.
Partes
No se especificaron partes.
  1. First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
    • First, completely loosen the 9.6 mm Phillips #2 screw on top. There is a plastic washer that holds the screw to the top cover, so it will not need to be taken out.
  2. After the screw has been loosened, lift the cover off.
    • After the screw has been loosened, lift the cover off.
  3. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  4. Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
    • Completely loosen the 9.6 mm Phillips #2 screw from the battery cover. Once again, there is a plastic washer to hold the screw to the cover.
  5. Lift the battery cover to gain access to the batteries.
    • Lift the battery cover to gain access to the batteries.
    • Replace the 3 AA batteries and reverse the steps to put everything back together.
Conclusión
Equipo
USF Tampa, Team 1-2, Hickman Fall 2014 Miembro de USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 20
Todo El Tiempo: 2,067
