Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Herramientas
No se especificaron herramientas.
  1. Remove both 8.0 mm Phillips #1 screws, one for each wheel.
    • Remove both 8.0 mm Phillips #1 screws, one for each wheel.
  2. Remove the wheels by pulling them away from the RC car.
    • Remove the wheels by pulling them away from the RC car.
  3. Make note of where each driving gear cover is placed. They only go in one way.
    • Make note of where each driving gear cover is placed. They only go in one way.
    • Remove the eight 8.0mm Phillips #00 screws, two screws for each wheel.
  4. Pry open the two gear covers on both sides.
    • Pry open the two gear covers on both sides.
  5. Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
    • Pull the driving gears off the axles by sliding them off the axles and exposing both axles.
  6. Slide both axles from the internal axles guides within the car.
    • Slide both axles from the internal axles guides within the car.
    • Reverse the steps to replace the axles.
Conclusión
Equipo
USF Tampa, Team 1-2, Hickman Fall 2014 Miembro de USF Tampa, Team 1-2, Hickman Fall 2014
USFT-HICKMAN-F14S1G2
3 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 206
