Saltar al contenido principal
Keyboard replacement on a why! W253EU
Qué necesitas
  1. Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: paso 1, imagen 1 de 3 Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: paso 1, imagen 2 de 3 Keyboard replacement on a why! W253EU, Battery from why! Remove W253EU: paso 1, imagen 3 de 3
    • Turn off the computer.
    • Before each operation it is important to start with the removal of the accumulator.
    • Take the slide unlocked into position, remove the battery.
  2. Keyboard replacement on a why! W253EU, Keyboard: paso 2, imagen 1 de 3 Keyboard replacement on a why! W253EU, Keyboard: paso 2, imagen 2 de 3 Keyboard replacement on a why! W253EU, Keyboard: paso 2, imagen 3 de 3
    • Use a Phillips # 1 screwdriver to remove the two screws located in the slot of the accumulator.
    • Insert a standard screwdriver into the slot in the cover above the keyboard.
    • Lift the cover with the usual care.
  3. Keyboard replacement on a why! W253EU: paso 3, imagen 1 de 3 Keyboard replacement on a why! W253EU: paso 3, imagen 2 de 3 Keyboard replacement on a why! W253EU: paso 3, imagen 3 de 3
    • Use a Phillips # 1 screwdriver to remove the four screws securing the keyboard in the upper part.
  4. Keyboard replacement on a why! W253EU: paso 4, imagen 1 de 2 Keyboard replacement on a why! W253EU: paso 4, imagen 2 de 2
    • Turn the keyboard towards the screen.
    • Carefully remove the connection cable in the direction of the plug axis.
Conclusión
For reassembly, follow the instructions in reverse order.
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
31,100 Reputación
264 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 20
Todo El Tiempo: 468
