Saltar al contenido principal
Introducción
Use this guide to remove or replace the baseplate of the Keurig K75 Platinum Brewing System. This allows the user to reach the internal parts of the Keurig B70 Platinum.
Partes
No se especificaron partes.
  1. Before beginning the repair, turn off the brewer and disconnect it from any power source. Move the brewer so that the metal baseplate is easily accessible.
    • Before beginning the repair, turn off the brewer and disconnect it from any power source.
    • Move the brewer so that the metal baseplate is easily accessible.
    • Remove the five silver 4 mm Phillips #2 screws from the baseplate.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Using a spudger, gently pry the metal baseplate from the brewer. Gently set down the baseplate.
    • Using a spudger, gently pry the metal baseplate from the brewer.
    • Gently set down the baseplate.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 20-2, Maness Winter 2013 Miembro de Cal Poly, Team 20-2, Maness Winter 2013
CPSU-MANESS-W13S20G2
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 2,588
