Saltar al contenido principal
Keurig K55 Water Filter Replacement
Qué necesitas
  1. Keurig K55 Water Filter Replacement, Charcoal water filter: paso 1, imagen 1 de 1
    • Soak the new charcoal filter in water for 5 minutes.
  2. Keurig K55 Water Filter Replacement: paso 2, imagen 1 de 3 Keurig K55 Water Filter Replacement: paso 2, imagen 2 de 3 Keurig K55 Water Filter Replacement: paso 2, imagen 3 de 3
    • Remove the water reservoir from the Keurig machine by gently lifting up on the reservoir and pulling it away.
  3. Keurig K55 Water Filter Replacement: paso 3, imagen 1 de 1
    • Remove the lid from the water reservoir and empty any remaining water from the tank.
  4. Keurig K55 Water Filter Replacement: paso 4, imagen 1 de 2 Keurig K55 Water Filter Replacement: paso 4, imagen 2 de 2
    • Remove water filter holder from within the water reservoir by pulling up on the holder and lifting it out.
  5. Keurig K55 Water Filter Replacement: paso 5, imagen 1 de 2 Keurig K55 Water Filter Replacement: paso 5, imagen 2 de 2
    • To remove the old filter, pinch both sides of the filter holder at the base and pull it apart. Remove the old filter by lifting it out of the filter holder.
    • Dispose of old water filter cartridge.
  6. Keurig K55 Water Filter Replacement: paso 6, imagen 1 de 1
    • Take the soaked water filter and rinse it under running water for 60 seconds.
  7. Keurig K55 Water Filter Replacement: paso 7, imagen 1 de 2 Keurig K55 Water Filter Replacement: paso 7, imagen 2 de 2
    • Place new water filter cartridge into the upper filter holder.
    • Snap the bottom of the filter holder back on by aligning the tabs with the spaces
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 26
Todo El Tiempo: 1,089
