Saltar al contenido principal
Keurig K40 Top Water Pump Replacement
Qué necesitas
  1. Keurig K40 Top Water Pump Replacement, Top Water Pump: paso 1, imagen 1 de 1
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Top Water Pump Replacement: paso 2, imagen 1 de 1
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Top Water Pump Replacement: paso 3, imagen 1 de 2 Keurig K40 Top Water Pump Replacement: paso 3, imagen 2 de 2
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Top Water Pump Replacement: paso 4, imagen 1 de 2 Keurig K40 Top Water Pump Replacement: paso 4, imagen 2 de 2
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team 6-1, Eyestone Spring 2016 Miembro de USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Miembros
5 Guías creadas
4 comentarios
I NEED ONE OF THESE! Where can I find one????
G Steve - Contestar
This is a check valve, not the water pump.
Rick Koen - Contestar
Please rename this article. The item is not a water pump.
tvyse46 - Contestar
I viewed this to replace the pump. But after the checkvalve was replaced through these instructions my K40 works like new. Thank you.
Glenn Stanley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 40
Todo El Tiempo: 9,511
