Saltar al contenido principal
Keurig K10 Mini Plus Cup Holder Replacement
Qué necesitas
  1. Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: paso 1, imagen 1 de 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: paso 1, imagen 2 de 3 Keurig K10 Mini Plus Cup Holder Replacement, Cup Holder: paso 1, imagen 3 de 3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 Mini Plus Cup Holder Replacement: paso 2, imagen 1 de 2 Keurig K10 Mini Plus Cup Holder Replacement: paso 2, imagen 2 de 2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
Conclusión
Mark Henein
Miembro Desde 02/04/16
369 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 17-6, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G6
Miembros de 2
4 Guías creadas
1Guía Comentario
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
Marie - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 1,526
