Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
The Water Pump within the Keurig K10 MINI Plus is a deeply embedded part. Due to the nature of it being attached both to an electrical source and a water source, it is not recommended to attempt this guide without previous familiarity with both.
  1. Lift the cold water reserve lid up to reveal its hinge. Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
    • Lift the cold water reserve lid up to reveal its hinge.
    • Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
  2. Repeat the last step on the other hinge, making sure to keep a firm grasp on the lid as it comes off to avoid dropping it.
    • Repeat the last step on the other hinge, making sure to keep a firm grasp on the lid as it comes off to avoid dropping it.
  3. Remove two 9 mm Phillips #1 screws. Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Once you remove the screws, the top cover should come out. You will then want to remove these screws which are the same size. The needle is sharp, so be careful.
    • Once you remove the screws, the top cover should come out.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
  6. Remove two 14 mm Phillips #2 screws. Remove two 12 mm Phillips #2 screws. Lift the arm off the assembly. This will reveal the tank hole as shown.
    • Remove two 14 mm Phillips #2 screws.
    • Remove two 12 mm Phillips #2 screws.
    • Lift the arm off the assembly. This will reveal the tank hole as shown.
    • It is recommended that you clog the tank hole with a napkin or something similar in order to prevent small parts from falling into the heating element.
  7. Remove two 9.7 mm Phillips #2 screws. Remove two 11.5 mm Phillips #2 screws.
    • Remove two 9.7 mm Phillips #2 screws.
    • Remove two 11.5 mm Phillips #2 screws.
    • Remove the cold water reserve arm's plug from the arm itself in order to allow access to the base screws.
  8. Remove two 18 mm Phillips #2 screws. Finally, detach the arm from the cold water reserve basin.
    • Remove two 18 mm Phillips #2 screws.
    • Finally, detach the arm from the cold water reserve basin.
  9. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  10. Pull the head assembly forward to reveal the two plastic axle points that keep the head assembly attached to the base. There is a spring concealed by a white piece as shown.
    • Pull the head assembly forward to reveal the two plastic axle points that keep the head assembly attached to the base.
    • There is a spring concealed by a white piece as shown.
  11. Using the iFixit Opening Tool, gently pry apart the plastic head assembly piece from both the body's axles and its left to remove it. Using the iFixit Opening Tool, gently pry apart the plastic head assembly piece from both the body's axles and its left to remove it.
    • Using the iFixit Opening Tool, gently pry apart the plastic head assembly piece from both the body's axles and its left to remove it.
  12. Remove two 14 mm Phillips #2 screws. Remove two 12 mm Phillips #2 screws. Screws circled in red may be hard to reach and will require a screw driver with a neck width of 5mm or less.
    • Screws circled in red may be hard to reach and will require a screw driver with a neck width of 5mm or less.
  13. Detach the seat by giving it a firm tug up. Detach the seat by giving it a firm tug up. Detach the seat by giving it a firm tug up.
    • Detach the seat by giving it a firm tug up.
  14. Flip over the device. Remove four 11.5 mm Phillips #2 screws.
    • Flip over the device.
    • Remove four 11.5 mm Phillips #2 screws.
  15. Reposition the metal lid while keeping the heat sink attached in order to reach the screws underneath. It is recommended that you leave the heat  sink aside as it contains thermal paste.
    • Reposition the metal lid while keeping the heat sink attached in order to reach the screws underneath.
    • It is recommended that you leave the heat sink aside as it contains thermal paste.
  16. Remove two 11.5 mm Phillips #2 screws. Be careful not to confuse these two screws for the ones behind them.
    • Be careful not to confuse these two screws for the ones behind them.
  17. Turn the device right side up again. Turn the device right side up again.
    • Turn the device right side up again.
  18. Begin to pry open the front plate using the iFixit Opening Tool as shown. Pry upwards in order to take the cover off. Pry upwards in order to take the cover off.
    • Begin to pry open the front plate using the iFixit Opening Tool as shown.
    • Pry upwards in order to take the cover off.
  19. Remove the front plate. Be careful of the wires here.
    • Remove the front plate.
    • Be careful of the wires here.
  20. Remove one 9.7 mm Phillips #2 screws. Remove one 9.7 mm Phillips #2 screws.
    • Remove one 9.7 mm Phillips #2 screws.
  21. Remove the button housing to access the buttons. The brew buttons can be easily popped out of place by pushing inwards from the front of the unit. The brew buttons can be easily popped out of place by pushing inwards from the front of the unit.
    • Remove the button housing to access the buttons.
    • The brew buttons can be easily popped out of place by pushing inwards from the front of the unit.
  22. Remove two 9.7 mm Phillips #2 screws. Remove two 9.7 mm Phillips #2 screws. Remove two 9.7 mm Phillips #2 screws.
  23. Pry open the left, right, and back of the back plate by pulling out and up. Do not be afraid to be fairly forceful when removing the back plate—it is snapped together fairly tight. Do not be afraid to be fairly forceful when removing the back plate—it is snapped together fairly tight.
    • Pry open the left, right, and back of the back plate by pulling out and up.
    • Do not be afraid to be fairly forceful when removing the back plate—it is snapped together fairly tight.
  24. Rotate the device to reveal the pump side. Remove one 9.7 mm Phillips #2 screw.
    • Rotate the device to reveal the pump side.
    • Remove one 9.7 mm Phillips #2 screw.
  25. Remove the power connectors attached to the water pump. Remove the water hose attached to the water pump.
    • Remove the power connectors attached to the water pump.
    • Remove the water hose attached to the water pump.
    • Remove the water pump itself.
Conclusión
4 personas más completaron esta guía.
Matt Bav
Miembro Desde 06/11/18
517 Reputación
4 Guías creadas
Equipo
Great directions on how to disassemble and get at the water pump. I just can’t find where or how to order a replacement pump. Can you help?
jameslitrun - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 76
Todo El Tiempo: 2,237
