Saltar al contenido principal
Keurig K10 MINI PLUS Top Needle Replacement
Qué necesitas
  1. Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: paso 1, imagen 1 de 3 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: paso 1, imagen 2 de 3 Keurig K10 MINI PLUS Top Needle Replacement, Cup Holder: paso 1, imagen 3 de 3
    • Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
  2. Keurig K10 MINI PLUS Top Needle Replacement: paso 2, imagen 1 de 2 Keurig K10 MINI PLUS Top Needle Replacement: paso 2, imagen 2 de 2
    • Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
  3. Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: paso 3, imagen 1 de 2 Keurig K10 MINI PLUS Top Needle Replacement, Top Needle: paso 3, imagen 2 de 2
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Top Needle Replacement: paso 4, imagen 1 de 3 Keurig K10 MINI PLUS Top Needle Replacement: paso 4, imagen 2 de 3 Keurig K10 MINI PLUS Top Needle Replacement: paso 4, imagen 3 de 3
    • Once you remove the screws, the top cover should come out.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Top Needle Replacement: paso 5, imagen 1 de 1
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
Conclusión
2 personas más completaron esta guía.
Mark Henein
Miembro Desde 02/04/16
369 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 17-6, Blackwell Winter 2016 Miembro de USF Tampa, Team 17-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G6
2 Miembros
2 Guías creadas
Un comentario
Where do you buy the needle I know you can get the exit needle with the holder, but can’t find this one.
tbushwacker - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 4,623
