Saltar al contenido principal
Keurig K10 MINI PLUS Dispenser Head Replacement
Qué necesitas
  1. Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Lid: paso 1, imagen 1 de 2 Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Lid: paso 1, imagen 2 de 2
    • Lift the cold water reserve lid up to reveal its hinge.
    • Using either the metal spudger or the opening tool, gently pry the plastic out of the metal axle.
  2. Keurig K10 MINI PLUS Dispenser Head Replacement: paso 2, imagen 1 de 1
    • Repeat the last step on the other hinge, making sure to keep a firm grasp on the lid as it comes off to avoid dropping it.
  3. Keurig K10 MINI PLUS Dispenser Head Replacement, Top Needle: paso 3, imagen 1 de 2 Keurig K10 MINI PLUS Dispenser Head Replacement, Top Needle: paso 3, imagen 2 de 2
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  4. Keurig K10 MINI PLUS Dispenser Head Replacement: paso 4, imagen 1 de 3 Keurig K10 MINI PLUS Dispenser Head Replacement: paso 4, imagen 2 de 3 Keurig K10 MINI PLUS Dispenser Head Replacement: paso 4, imagen 3 de 3
    • Once you remove the screws, the top cover should come out.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  5. Keurig K10 MINI PLUS Dispenser Head Replacement: paso 5, imagen 1 de 1
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
  6. Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Arm: paso 6, imagen 1 de 3 Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Arm: paso 6, imagen 2 de 3 Keurig K10 MINI PLUS Dispenser Head Replacement, Cold Water Reserve Arm: paso 6, imagen 3 de 3
    • Remove two 14 mm Phillips #2 screws.
    • Remove two 12 mm Phillips #2 screws.
    • Lift the arm off the assembly. This will reveal the tank hole as shown.
    • It is recommended that you clog the tank hole with a napkin or something similar in order to prevent small parts from falling into the heating element.
  7. Keurig K10 MINI PLUS Dispenser Head Replacement: paso 7, imagen 1 de 2 Keurig K10 MINI PLUS Dispenser Head Replacement: paso 7, imagen 2 de 2
    • Remove two 9.7 mm Phillips #2 screws.
    • Remove two 11.5 mm Phillips #2 screws.
    • Remove the cold water reserve arm's plug from the arm itself in order to allow access to the base screws.
  8. Keurig K10 MINI PLUS Dispenser Head Replacement: paso 8, imagen 1 de 2 Keurig K10 MINI PLUS Dispenser Head Replacement: paso 8, imagen 2 de 2
    • Remove two 18 mm Phillips #2 screws.
    • Finally, detach the arm from the cold water reserve basin.
  9. Keurig K10 MINI PLUS Dispenser Head Replacement, Dispenser Head: paso 9, imagen 1 de 2 Keurig K10 MINI PLUS Dispenser Head Replacement, Dispenser Head: paso 9, imagen 2 de 2
    • Pull the head assembly forward to reveal the two plastic axle points that keep the head assembly attached to the base.
    • There is a spring concealed by a white piece as shown.
  10. Keurig K10 MINI PLUS Dispenser Head Replacement: paso 10, imagen 1 de 2 Keurig K10 MINI PLUS Dispenser Head Replacement: paso 10, imagen 2 de 2
    • Using the iFixit Opening Tool, gently pry apart the plastic head assembly piece from both the body's axles and its left to remove it.
Conclusión
Matt Bav
Miembro Desde 11/06/18
562 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 834
