Saltar al contenido principal
Keurig B70 Platinum Water Filter Replacement
Qué necesitas
  1. Keurig B70 Platinum Water Filter Replacement, Water Filter: paso 1, imagen 1 de 3 Keurig B70 Platinum Water Filter Replacement, Water Filter: paso 1, imagen 2 de 3 Keurig B70 Platinum Water Filter Replacement, Water Filter: paso 1, imagen 3 de 3
    • Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
    • Be sure to empty the reservoir before continuing to the next step.
  2. Keurig B70 Platinum Water Filter Replacement: paso 2, imagen 1 de 3 Keurig B70 Platinum Water Filter Replacement: paso 2, imagen 2 de 3 Keurig B70 Platinum Water Filter Replacement: paso 2, imagen 3 de 3
    • Remove the three 11.0 mm screws from the reservoir filter.
    • You may need to use tweezers to pull out the screws.
  3. Keurig B70 Platinum Water Filter Replacement: paso 3, imagen 1 de 3 Keurig B70 Platinum Water Filter Replacement: paso 3, imagen 2 de 3 Keurig B70 Platinum Water Filter Replacement: paso 3, imagen 3 de 3
    • Firmly twist the filter counterclockwise to remove it.
    • When adding the replacement filter, make sure the filter lines up with the screw holes.
Conclusión
Emily Ramirez
Miembro Desde 10/14/18
97 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team S1-G6, Rose Fall 2018 Miembro de UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
4 Miembros
5 Guías creadas
2 comentarios
What are the two items inside the water resin?
There is the round item, and next to it an oblong item. I am really confused
Joan - Contestar
I just ordered a filter starter kit. Do I just insert the kit on top of the round item?
Joan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 17
Ultimos 30 días: 110
Todo El Tiempo: 9,150
