Introducción
Clogged filter?
This guide will show you how to remove the water filter found inside the Keurig B70 Platinum water reservoir.
You will only need a Phillips #2 screwdriver for this guide.
Qué necesitas
Remove the water reservoir from the Keurig by lifting it upwards and pulling it outwards.
4 comentarios
I just ordered a filter starter kit. Do I just insert the kit on top of the round item?
I bought a Kuerig tall handle starter kit with charcoal filters. Tried install it over the existing built in filter, it didn’t fit. I think the round filter has to be removed in order to use the starter kit.
