Saltar al contenido principal
Keurig B70 Platinum Puncture Needle Replacement
Qué necesitas
  1. Keurig B70 Platinum Puncture Needle Replacement, Brewer Handle: paso 1, imagen 1 de 3 Keurig B70 Platinum Puncture Needle Replacement, Brewer Handle: paso 1, imagen 2 de 3 Keurig B70 Platinum Puncture Needle Replacement, Brewer Handle: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Turn off and unplug the Keurig before starting.
    • Lay the Keurig on its back and open the lid.
    • Using a Phillips #2 screwdriver, remove the two 21.0 mm screws.
    • Be careful when removing the screws. There is a sharp puncture needle!
    • You may need to use tweezers to get the screws out.
  2. Keurig B70 Platinum Puncture Needle Replacement: paso 2, imagen 1 de 2 Keurig B70 Platinum Puncture Needle Replacement: paso 2, imagen 2 de 2
    • Using a T15 Torx screwdriver, remove the two 29.0 mm screws on each ends of the handle.
  3. Keurig B70 Platinum Puncture Needle Replacement: paso 3, imagen 1 de 2 Keurig B70 Platinum Puncture Needle Replacement: paso 3, imagen 2 de 2
    • Lift and pull the black plastic cover away from the Keurig.
  4. Keurig B70 Platinum Puncture Needle Replacement: paso 4, imagen 1 de 1
    • Push the handle back and upward to detach it from the Keurig.
  5. Keurig B70 Platinum Puncture Needle Replacement, Puncture Needle: paso 5, imagen 1 de 2 Keurig B70 Platinum Puncture Needle Replacement, Puncture Needle: paso 5, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the two 7.0 mm screws located on the sides of the tube near the puncture needle.
  6. Keurig B70 Platinum Puncture Needle Replacement: paso 6, imagen 1 de 2 Keurig B70 Platinum Puncture Needle Replacement: paso 6, imagen 2 de 2
    • Using both hands, pull the puncture needle tube and the Keurig tube apart to disconnect the tubes.
    • Don't be afraid to pull hard! The tubes are tightly connected.
  7. Keurig B70 Platinum Puncture Needle Replacement: paso 7, imagen 1 de 2 Keurig B70 Platinum Puncture Needle Replacement: paso 7, imagen 2 de 2
    • Slide the black plastic ring, which holds the puncture needle tube down, off of the tube.
  8. Keurig B70 Platinum Puncture Needle Replacement: paso 8, imagen 1 de 3 Keurig B70 Platinum Puncture Needle Replacement: paso 8, imagen 2 de 3 Keurig B70 Platinum Puncture Needle Replacement: paso 8, imagen 3 de 3
    • Using a Phillips #2 screwdriver, remove the two 9.0 mm screws next to the detached tube.
    • Hold on to the puncture needle when removing the screws to ensure that the puncture needle does not fall and cause injury.
  9. Keurig B70 Platinum Puncture Needle Replacement: paso 9, imagen 1 de 3 Keurig B70 Platinum Puncture Needle Replacement: paso 9, imagen 2 de 3 Keurig B70 Platinum Puncture Needle Replacement: paso 9, imagen 3 de 3
    • Gently pull the puncture needle down and out from the Keurig.
Conclusión
Steven Tran
Miembro Desde 10/14/18
329 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team S1-G6, Rose Fall 2018 Miembro de UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 25
Todo El Tiempo: 1,257
