Saltar al contenido principal
Keurig B70 Platinum K-Cup Portion Pack Holder Replacement
Qué necesitas
  1. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement, K-Cup Portion Pack Holder: paso 1, imagen 1 de 2 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement, K-Cup Portion Pack Holder: paso 1, imagen 2 de 2
    • Turn off and unplug the Keurig before starting.
    • Open the lid and remove the two 11.0 mm screws located below the K-Cup holder.
  2. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: paso 2, imagen 1 de 1
    • Pull the black plastic guard of the K-Cup housing away from the Keurig.
    • Depending on the angle, the guard can actually fall out instead. Be ready to catch it!
  3. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: paso 3, imagen 1 de 3 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: paso 3, imagen 2 de 3 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: paso 3, imagen 3 de 3
    • Push the black button at the bottom of the lid to remove the K-cup holder assembly.
    • From the top, lift the assembly out of the Keurig.
  4. Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: paso 4, imagen 1 de 2 Keurig B70 Platinum K-Cup Portion Pack Holder Replacement: paso 4, imagen 2 de 2
    • Grab the top and the bottom of the holder assembly and pull it apart.
    • Be careful when pulling the assembly. There is a sharp needle!
    • This step requires a little force.
Conclusión
Thu Hoang
Miembro Desde 10/17/18
217 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team S1-G6, Rose Fall 2018 Miembro de UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
4 Miembros
5 Guías creadas
Un comentario
Spring flew out as I was removing cup holder. Where does it go. How do I reinsert it?
slz2002 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 1,200
