Saltar al contenido principal
Keurig B70 Platinum Base Replacement
Qué necesitas
  1. Keurig B70 Platinum Base Replacement, Base: paso 1, imagen 1 de 2 Keurig B70 Platinum Base Replacement, Base: paso 1, imagen 2 de 2
    • Turn off and unplug the Keurig before starting.
    • Turn the Keurig upside down so the metal base is exposed.
    • Remove the five 12.0 mm screws.
  2. Keurig B70 Platinum Base Replacement: paso 2, imagen 1 de 2 Keurig B70 Platinum Base Replacement: paso 2, imagen 2 de 2
    • Lift the metal plate off the Keurig and hang it over the side of the device.
    • Be careful! The metal plate is sharp!
    • There are wires connected to the metal plate. Make sure the wires are not in the way of the internal components.
  3. Keurig B70 Platinum Base Replacement: paso 3, imagen 1 de 3 Keurig B70 Platinum Base Replacement: paso 3, imagen 2 de 3 Keurig B70 Platinum Base Replacement: paso 3, imagen 3 de 3
    • Remove the three 11.0 mm screws located on the upper left side of the base from within the tub-looking area.
    • Pull out the red and white wires and put it off to the side of the Keurig.
  4. Keurig B70 Platinum Base Replacement: paso 4, imagen 1 de 3 Keurig B70 Platinum Base Replacement: paso 4, imagen 2 de 3 Keurig B70 Platinum Base Replacement: paso 4, imagen 3 de 3
    • Pull out the water collector by gripping it tightly and lifting upwards.
  5. Keurig B70 Platinum Base Replacement: paso 5, imagen 1 de 3 Keurig B70 Platinum Base Replacement: paso 5, imagen 2 de 3 Keurig B70 Platinum Base Replacement: paso 5, imagen 3 de 3
    • Lift the tube, connected to the tank, off the black plastic hook and leave it off to the side of the hook.
  6. Keurig B70 Platinum Base Replacement: paso 6, imagen 1 de 3 Keurig B70 Platinum Base Replacement: paso 6, imagen 2 de 3 Keurig B70 Platinum Base Replacement: paso 6, imagen 3 de 3
    • Pull the power cord out from the plastic holder located near the water tank.
    • This step requires a bit of force so don't be afraid to pull harder!
  7. Keurig B70 Platinum Base Replacement: paso 7, imagen 1 de 2 Keurig B70 Platinum Base Replacement: paso 7, imagen 2 de 2
    • Remove the six 13.0 mm screws.
  8. Keurig B70 Platinum Base Replacement: paso 8, imagen 1 de 3 Keurig B70 Platinum Base Replacement: paso 8, imagen 2 de 3 Keurig B70 Platinum Base Replacement: paso 8, imagen 3 de 3
    • Lift the metal base and hover it over the opening of the black plastic base.
    • Carefully raise the plastic base over the metal base until it is removed.
    • Make sure to pull the power cord through the base as well!
Conclusión
Steven Tran
Miembro Desde 10/14/18
329 Reputación
2 Guías creadas
Equipo
UW Tacoma, Team S1-G6, Rose Fall 2018 Miembro de UW Tacoma, Team S1-G6, Rose Fall 2018
UWT-ROSE-F18S1G6
Miembros de 4
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 681
