Saltar al contenido principal
Kenwood KDC-BT362U DVD-Drive Replacement
Qué necesitas
  1. Kenwood KDC-BT362U DVD-Drive Replacement, Front Panel: paso 1, imagen 1 de 1
    • Locate the face-plate eject button.
  2. Kenwood KDC-BT362U DVD-Drive Replacement: paso 2, imagen 1 de 2 Kenwood KDC-BT362U DVD-Drive Replacement: paso 2, imagen 2 de 2
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Kenwood KDC-BT362U DVD-Drive Replacement: paso 3, imagen 1 de 2 Kenwood KDC-BT362U DVD-Drive Replacement: paso 3, imagen 2 de 2
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Kenwood KDC-BT362U DVD-Drive Replacement: paso 4, imagen 1 de 2 Kenwood KDC-BT362U DVD-Drive Replacement: paso 4, imagen 2 de 2
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Kenwood KDC-BT362U DVD-Drive Replacement: paso 5, imagen 1 de 1
    • Remove the front panel.
  6. Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: paso 6, imagen 1 de 3 Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: paso 6, imagen 2 de 3 Kenwood KDC-BT362U DVD-Drive Replacement, Metal Case: paso 6, imagen 3 de 3
    • Use the Phillips #0 Screwdriver to remove the screws off of the metal case.
  7. Kenwood KDC-BT362U DVD-Drive Replacement: paso 7, imagen 1 de 3 Kenwood KDC-BT362U DVD-Drive Replacement: paso 7, imagen 2 de 3 Kenwood KDC-BT362U DVD-Drive Replacement: paso 7, imagen 3 de 3
    • Carefully separate the top and bottom halves of the metal case apart.
    • Do not separate the metal case halves completely.
    • Carefully pull the DVD-Drive ribbon cable from the motherboard.
  8. Kenwood KDC-BT362U DVD-Drive Replacement, DVD-Drive: paso 8, imagen 1 de 2 Kenwood KDC-BT362U DVD-Drive Replacement, DVD-Drive: paso 8, imagen 2 de 2
    • Use the Phillips #0 Screwdriver to remove the three screws.
  9. Kenwood KDC-BT362U DVD-Drive Replacement: paso 9, imagen 1 de 1
    • Lift the DVD-Drive to separate it from the metal case.
Conclusión
Steven Chov
Miembro Desde 10/04/16
349 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-5, Cagle Fall 2016 Miembro de USF Tampa, Team 2-5, Cagle Fall 2016
USFT-CAGLE-F16S2G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 474
