Saltar al contenido principal
Kenwood DNX571HD Cooling Fan Replacement
Qué necesitas
  1. Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: paso 1, imagen 1 de 2 Kenwood DNX571HD Cooling Fan Replacement, CD/DVD Drive: paso 1, imagen 2 de 2
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD Cooling Fan Replacement: paso 2, imagen 1 de 3 Kenwood DNX571HD Cooling Fan Replacement: paso 2, imagen 2 de 3 Kenwood DNX571HD Cooling Fan Replacement: paso 2, imagen 3 de 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD Cooling Fan Replacement: paso 3, imagen 1 de 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD Cooling Fan Replacement: paso 4, imagen 1 de 3 Kenwood DNX571HD Cooling Fan Replacement: paso 4, imagen 2 de 3 Kenwood DNX571HD Cooling Fan Replacement: paso 4, imagen 3 de 3
    • Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
    • Lift up to remove the top casing.
  5. Kenwood DNX571HD Cooling Fan Replacement: paso 5, imagen 1 de 1
    • Lift the CD drive carefully to expose the attached cable underneath.
  6. Kenwood DNX571HD Cooling Fan Replacement: paso 6, imagen 1 de 2 Kenwood DNX571HD Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
  7. Kenwood DNX571HD Cooling Fan Replacement, Cooling Fan: paso 7, imagen 1 de 1
    • Carefully unplug the fan power cord with the tweezers.
  8. Kenwood DNX571HD Cooling Fan Replacement: paso 8, imagen 1 de 2 Kenwood DNX571HD Cooling Fan Replacement: paso 8, imagen 2 de 2
    • Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
    • Remove the metal plate
    • Removing the plate will damage the heat sink compound. This will need to be replaced during reassembly.
  9. Kenwood DNX571HD Cooling Fan Replacement: paso 9, imagen 1 de 2 Kenwood DNX571HD Cooling Fan Replacement: paso 9, imagen 2 de 2
    • Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
  10. Kenwood DNX571HD Cooling Fan Replacement: paso 10, imagen 1 de 3 Kenwood DNX571HD Cooling Fan Replacement: paso 10, imagen 2 de 3 Kenwood DNX571HD Cooling Fan Replacement: paso 10, imagen 3 de 3
    • Remove the four 5.5mm screws with the Phillips #1 screwdriver.
  11. Kenwood DNX571HD Cooling Fan Replacement: paso 11, imagen 1 de 1
    • Lift the top part of the unit up from the lower chassis.
  12. Kenwood DNX571HD Cooling Fan Replacement: paso 12, imagen 1 de 2 Kenwood DNX571HD Cooling Fan Replacement: paso 12, imagen 2 de 2
    • Remove the two 13mm long screws with a Phillips #1 screwdriver.
    • Gently thread the power cable through the circuit boards to separate the fan from the body of the stereo.
Conclusión
Wendy Zaballos
Miembro Desde 09/17/18
952 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 845
