Saltar al contenido principal
Kenmore 78423 Dustbin filter Replacement
  1. Kenmore 78423 Dustbin filter Replacement, Dust Bin: paso 1, imagen 1 de 2 Kenmore 78423 Dustbin filter Replacement, Dust Bin: paso 1, imagen 2 de 2
    • Grab the dustbin handle, press and hold the button at the top of the handle.
    • Pull the dustbin up and away from the main body.
  2. Kenmore 78423 Dustbin filter Replacement: paso 2, imagen 1 de 2 Kenmore 78423 Dustbin filter Replacement: paso 2, imagen 2 de 2
    • Press the button located beneath the circular opening on the dust bin; this will open the bottom of the dustbin.
    • Properly dispose any contents of the dust bin into a wastebasket.
  3. Kenmore 78423 Dustbin filter Replacement, Dustbin Filters: paso 3, imagen 1 de 3 Kenmore 78423 Dustbin filter Replacement, Dustbin Filters: paso 3, imagen 2 de 3 Kenmore 78423 Dustbin filter Replacement, Dustbin Filters: paso 3, imagen 3 de 3
    • Pinch and grasp the raised handle on the primary dustbin filter.
    • Lift the primary dustbin filter up and away from the dustbin and place it to the side.
  4. Kenmore 78423 Dustbin filter Replacement: paso 4, imagen 1 de 2 Kenmore 78423 Dustbin filter Replacement: paso 4, imagen 2 de 2
    • Grasp the foam filter and lift up to remove.
    • The foam filter may be lodged inside of the primary dustbin filter. In this case, both filters may be removed at the same time.
Conclusión
Una persona más ha completado esta guía.
Equipo
CSU Fullerton, Team S2-G4, Bruce Fall 2018 Miembro de CSU Fullerton, Team S2-G4, Bruce Fall 2018
CSUF-BRUCE-F18S2G4
4 Miembros
10 Guías creadas
2 comentarios
What is the part number so I can purchase and replace dustbin filter
Bob Roper - Contestar
Kenmore 78423 Dustbin Filters, where can I purchase new ones?
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 26
Todo El Tiempo: 904
