Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Kenmore 110 Series Washing Machine Water Level Sensor Replacement
Qué necesitas
  1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement, Water Level Sensor: paso 1, imagen 1 de 1
    • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury. Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: paso 2, imagen 1 de 3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: paso 2, imagen 2 de 3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: paso 2, imagen 3 de 3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: paso 3, imagen 1 de 3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: paso 3, imagen 2 de 3 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: paso 3, imagen 3 de 3
    • Remove wires from water level sensor.
    • With a Phillips screwdriver remove the mounting screw.
    • Cut the zip tie and remove water level hose.
Conclusión
5 personas más completaron esta guía.
Robert Trout
Miembro Desde 09/26/12
1,234 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 15-43, Forte Fall 2012 Miembro de Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
Miembros de 5
12 Guías creadas
4Guía Comentarios
how to test water level switch??
countryrhoads4x4 - Contestar Compartir
What is the water sensor part # for a Kenmore model #11029842990?
Who has that part 4the best price?
Rod Brannon - Contestar Compartir
Hi,
I replaced the water-level pressure switch with a new kit but it did not resolve my problem. After installing the switch and line, I selected the lowest level but the tub continued to fill beyond the smallest wash level. I have a Kenmore Model # 110.20902. What other part or solution could resolve my issue?
BTW: I read replacing the water inlet valve night be involved but I already did that within the last six months and everything worked fine until I noticed the water level had changed the last two washes to a large load only. In fact, the water looked above the large level during my last wash.
I would appreciate any insight.
Shannon
Shannon - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 55
Ultimos 30 días: 153
Todo El Tiempo: 43,178
