Saltar al contenido principal
Kenmore 110 Series Washing Machine Drive Belt Replacement
Qué necesitas
  1. Kenmore 110 Series Washing Machine Drive Belt Replacement, Drive Belt: paso 1, imagen 1 de 1
    • To avoid risk of electric shock, unplug the washing machine.
    • Lay the washing machine on its back.
  2. Kenmore 110 Series Washing Machine Drive Belt Replacement: paso 2, imagen 1 de 3 Kenmore 110 Series Washing Machine Drive Belt Replacement: paso 2, imagen 2 de 3 Kenmore 110 Series Washing Machine Drive Belt Replacement: paso 2, imagen 3 de 3
    • Using a 5/16" socket wrench, remove both screws from the belt cover.
    • Remove the belt cover from the washer.
  3. Kenmore 110 Series Washing Machine Drive Belt Replacement: paso 3, imagen 1 de 3 Kenmore 110 Series Washing Machine Drive Belt Replacement: paso 3, imagen 2 de 3 Kenmore 110 Series Washing Machine Drive Belt Replacement: paso 3, imagen 3 de 3
    • Using a 1/2" socket, remove the bolt securing the drive pulley.
    • Remove the drive pulley and belt.
    • When installing a new belt, wrap the belt around both the motor and drive pulleys before reinstalling the drive pulley.
Conclusión
16 personas más completaron esta guía.
Robert Trout
Miembro Desde 09/26/12
1,168 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 15-43, Forte Fall 2012 Miembro de Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Miembros
10 Guías creadas
5 comentarios
What would be reason that rinse cycle doesn't spin and it leaks
lauraleahenquinette - Contestar
Will the drive belt make a clicking/grinding noise? I originally thought it was just a slipping noise, but empty it does make the grinding noise.
Gary Long Jr - Contestar
It makes noise like it’s working but it’s not grabbing anything
Ricardo Vallegos - Contestar
You can change your gearbox
Adarsh Pandey -
What belt type should I use for a 110.24642300? I cannot find its belt online.
Elizabeth Glenski - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 16
Ultimos 7 días: 189
Ultimos 30 días: 810
Todo El Tiempo: 112,489
