Saltar al contenido principal
Kemove Snowfox 61 Key Switch Replacement
Qué necesitas
  1. Kemove Snowfox 61 Key Switch Replacement, Key Switch: paso 1, imagen 1 de 3 Kemove Snowfox 61 Key Switch Replacement, Key Switch: paso 1, imagen 2 de 3 Kemove Snowfox 61 Key Switch Replacement, Key Switch: paso 1, imagen 3 de 3
    • Do not disassemble the keyboard if the keyboard is connected to a power source.
    • Unplug the power cable from the keyboard.
  2. Kemove Snowfox 61 Key Switch Replacement: paso 2, imagen 1 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 2, imagen 2 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 2, imagen 3 de 3
    • Do not pull the keycap other than straight up.
    • Position the keycap puller directly above the keycap.
    • Push the keycap puller down until the two handles are underneath the keycap.
    • Remove all keys.
    • It may be easier to pull by rotating the puller at a 45-degree angle.
  3. Kemove Snowfox 61 Key Switch Replacement: paso 3, imagen 1 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 3, imagen 2 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 3, imagen 3 de 3
    • Fill the plastic container with water.
    • Add 2-3 drops of dish soap.
    • Put the keycaps in.
    • Let the keycaps soak for about 20-30 minutes.
  4. Kemove Snowfox 61 Key Switch Replacement: paso 4, imagen 1 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 4, imagen 2 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Microfiber Cleaning Cloths
    $3.99
    Comprar
    • Do not leave in sunlight or use a hairdryer because the heat might cause the plastic to warp or bend.
    • Take out the keycaps.
    • Ensure that the keycaps are separated and facing down.
    • Let the keycaps dry for 45 minutes.
    • If you cannot wait for 45 minutes, you may use a microfiber cloth and hand dry the keycaps. But be thorough in the cleaning process as there may be excess water inside the keycaps.
  5. Kemove Snowfox 61 Key Switch Replacement: paso 5, imagen 1 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 5, imagen 2 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 5, imagen 3 de 3
    • Do not pull the key switch other than straight up.
    • Place the key switch puller above the key switch.
    • Push the tongs inward on both the white top and bottom ends.
    • Pull the key switch out.
    • Remove all key switches.
  6. Kemove Snowfox 61 Key Switch Replacement: paso 6, imagen 1 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 6, imagen 2 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 6, imagen 3 de 3
    Comprar
    • Do not squeeze or clean roughly as you may leak liquid into the board's interior.
    • Use a wet/ alcohol wipe and gently clean the surface board.
    • Use any tweezers or cotton swabs to clean tight corners of the board.
  7. Kemove Snowfox 61 Key Switch Replacement: paso 7, imagen 1 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 7, imagen 2 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 7, imagen 3 de 3
    • Do not bend or hold by the golden pins.
    • Match the key switch with the keyholes.
    • Align the two golden pins with the two tiny holes located by the bottom.
    • Push down.
    • You will hear a loud clicking noise when the key switch has locked in place.
  8. Kemove Snowfox 61 Key Switch Replacement: paso 8, imagen 1 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 8, imagen 2 de 3 Kemove Snowfox 61 Key Switch Replacement: paso 8, imagen 3 de 3
    • Match the keycaps with the key switches.
    • Align the keycaps facing down and push straight.
    • Place all keycaps in their respective positions.
Conclusión
Just like brand new!
Chandara Young
Miembro Desde 10/05/21
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 33
Todo El Tiempo: 829
