Saltar al contenido principal
Kawasaki Ninja 300 Seat Replacement
Qué necesitas
  1. Kawasaki Ninja 300 Seat Replacement, Seat: paso 1, imagen 1 de 3 Kawasaki Ninja 300 Seat Replacement, Seat: paso 1, imagen 2 de 3 Kawasaki Ninja 300 Seat Replacement, Seat: paso 1, imagen 3 de 3
    • Locate the bolt holding the side seat cover in place and remove it using a 4mm hex key.
    • Make sure to also remove the bolt's washer.
  2. Kawasaki Ninja 300 Seat Replacement: paso 2, imagen 1 de 3 Kawasaki Ninja 300 Seat Replacement: paso 2, imagen 2 de 3 Kawasaki Ninja 300 Seat Replacement: paso 2, imagen 3 de 3
    • If you're working in cold conditions, be careful not to break the side seat cover.
    • Reach under the side seat cover and firmly pull it out to unseat it from its rubber clips. There is one at the rear of the cover and two at the front.
  3. Kawasaki Ninja 300 Seat Replacement: paso 3, imagen 1 de 3 Kawasaki Ninja 300 Seat Replacement: paso 3, imagen 2 de 3 Kawasaki Ninja 300 Seat Replacement: paso 3, imagen 3 de 3
    • Locate the seat bolt and remove it using a 5mm hex key.
    • It's best to use the longer end of the hex key, as the shorter end won't quite fit.
    • Repeat these steps on the other side of the motorcycle before continuing on to the next step.
  4. Kawasaki Ninja 300 Seat Replacement: paso 4, imagen 1 de 3 Kawasaki Ninja 300 Seat Replacement: paso 4, imagen 2 de 3 Kawasaki Ninja 300 Seat Replacement: paso 4, imagen 3 de 3
    • Grab the front section of the seat and slightly lift it up and back to remove it.
Conclusión
2 personas más completaron esta guía.
Craig Lloyd
Miembro Desde 02/10/16
35,407 Reputación
82 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 39
Ultimos 30 días: 146
Todo El Tiempo: 12,215
