Saltar al contenido principal
KYVOL CYBOVAC E20 Wheel Assembly Replacement
Qué necesitas
  1. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: paso 1, imagen 1 de 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Battery: paso 1, imagen 2 de 2
    • Start by laying the device on a flat surface with the logo facing up.
    • Flip the device over.
  2. KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 2, imagen 1 de 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 2, imagen 2 de 2
    • Remove two 1 mm screws using a Phillips #00 screwdriver.
  3. KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 3, imagen 1 de 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 3, imagen 2 de 2
    • Remove the cover.
  4. KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 4, imagen 1 de 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 4, imagen 2 de 2
    • Lift the battery.
    • Press down on the top of the white connector.
    • Remove the battery from the vacuum.
  5. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel: paso 5, imagen 1 de 1
    • Remove both sweepers by pinching near the base of the brushes and pulling up.
  6. KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 6, imagen 1 de 1
    • Remove four 10 mm screws using a Phillips #00 screwdriver.
  7. KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 7, imagen 1 de 3 KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 7, imagen 2 de 3 KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 7, imagen 3 de 3
    • Lift the wheel to detach the tensioning spring. This step requires you to first press down on the wheel, then detach.
    • Disconnect the wheel motor from the power supply.
    • Repeat the process for the other wheel.
  8. KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: paso 8, imagen 1 de 3 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: paso 8, imagen 2 de 3 KYVOL CYBOVAC E20 Wheel Assembly Replacement, Wheel Assembly: paso 8, imagen 3 de 3
    • Remove six 10 mm screws from the housing using a Phillips #00 screwdriver.
    • Open the gearbox.
  9. KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 9, imagen 1 de 1
    • Gently remove each gear.
  10. KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 10, imagen 1 de 2 KYVOL CYBOVAC E20 Wheel Assembly Replacement: paso 10, imagen 2 de 2
    • Use a J1 screw driver to remove two 6 mm screws from the gearbox.
Conclusión
Randall Morgan
Miembro Desde 07/13/23
380 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-1, Harley Summer 2023 Miembro de IUPUI, Team 1-1, Harley Summer 2023
IUPUI-HARLEY-SU23S1G1
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 249
