Saltar al contenido principal
KPN Arizona Comfort Replacement
Qué necesitas
  1. KPN Arizona Comfort Replacement, KPN Arizona Comfort: paso 1, imagen 1 de 3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: paso 1, imagen 2 de 3 KPN Arizona Comfort Replacement, KPN Arizona Comfort: paso 1, imagen 3 de 3
    • Hold the phone with one hand and apply a slight pressure on the battery lid with your other hand.
    • Now you can slide open the battery lid.
  2. KPN Arizona Comfort Replacement: paso 2, imagen 1 de 1
    • Lift out both batteries with a prying movement.
  3. KPN Arizona Comfort Replacement: paso 3, imagen 1 de 3 KPN Arizona Comfort Replacement: paso 3, imagen 2 de 3 KPN Arizona Comfort Replacement: paso 3, imagen 3 de 3
    • Remove the following two Phillips #00 screws securing the back casing to the front.
  4. KPN Arizona Comfort Replacement: paso 4, imagen 1 de 3 KPN Arizona Comfort Replacement: paso 4, imagen 2 de 3 KPN Arizona Comfort Replacement: paso 4, imagen 3 de 3
    • Use the plastic opening tool to pry the front from the backside.
    • Start prying at the bottom and work your way around the device.
    • Do this for every 3 cm all around.
    • If you apply too much pressure or use a sharp tool, this might damage the casing.
  5. KPN Arizona Comfort Replacement: paso 5, imagen 1 de 3 KPN Arizona Comfort Replacement: paso 5, imagen 2 de 3 KPN Arizona Comfort Replacement: paso 5, imagen 3 de 3
    • Flip the circuit board from the backside of the phone to the frontside of the phone by tilting it on the long edge
    • Make sure you do this gesture slowly and gently so the wires will not detach.
  6. KPN Arizona Comfort Replacement: paso 6, imagen 1 de 3 KPN Arizona Comfort Replacement: paso 6, imagen 2 de 3 KPN Arizona Comfort Replacement: paso 6, imagen 3 de 3
    • You are now facing the back side. Apply a little bit of pressure with the plastic opening tool on the back of the speaker so the the speaker can pop out.
    • The speaker is still attached with a wire, do not pull this.
  7. KPN Arizona Comfort Replacement: paso 7, imagen 1 de 2 KPN Arizona Comfort Replacement: paso 7, imagen 2 de 2
    • Use a soldering iron to heat up the solder connected to the electric wire.
    • When the solder is fluid, carefully pull the electric wire loose.
  8. KPN Arizona Comfort Replacement: paso 8, imagen 1 de 2 KPN Arizona Comfort Replacement: paso 8, imagen 2 de 2
    • Replace the broken speaker of the phone and solder it back in place.
Conclusión
To reassemble your device, follow these instructions from step 6 in reverse order.
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 553
