Saltar al contenido principal
KDDI Kyocera A5521K Front LCD Screen Replacement
Qué necesitas
  1. KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: paso 1, imagen 1 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: paso 1, imagen 2 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: paso 1, imagen 3 de 3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  2. KDDI Kyocera A5521K Front LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the screws using a Y0 screwdriver.
  3. KDDI Kyocera A5521K Front LCD Screen Replacement: paso 3, imagen 1 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement: paso 3, imagen 2 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement: paso 3, imagen 3 de 3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  4. KDDI Kyocera A5521K Front LCD Screen Replacement: paso 4, imagen 1 de 1
    • Use the Y0 screwdriver to remove the screws.
  5. KDDI Kyocera A5521K Front LCD Screen Replacement: paso 5, imagen 1 de 2 KDDI Kyocera A5521K Front LCD Screen Replacement: paso 5, imagen 2 de 2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  6. KDDI Kyocera A5521K Front LCD Screen Replacement: paso 6, imagen 1 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement: paso 6, imagen 2 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement: paso 6, imagen 3 de 3
    • Separate the faceplate from the phone.
  7. KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: paso 7, imagen 1 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: paso 7, imagen 2 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: paso 7, imagen 3 de 3
    • Rotate the phone 180 degrees.
    • Grab the flexible circuit with tweezers (or use your fingers if you can manage a firm grip).
    • Pull the flexible circuit to towards you to separate the front LCD screen from the phone.
  8. KDDI Kyocera A5521K Front LCD Screen Replacement: paso 8, imagen 1 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement: paso 8, imagen 2 de 3 KDDI Kyocera A5521K Front LCD Screen Replacement: paso 8, imagen 3 de 3
    • Firmly pull the flexible circuit from the connector.
    • Be careful not to damage the flexible circuit.
    • The front LCD screen should now be separate from the phone.
Conclusión
Dominic Grisafe
Miembro Desde 04/15/10
157 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 28-25, Regan Spring 2010 Miembro de Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Miembros
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 1,502
