Saltar al contenido principal
Justin Bieber Concert Microphone Speaker Replacement
Qué necesitas
  1. Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: paso 1, imagen 1 de 2 Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Speaker Replacement, Removing batteries: paso 2, imagen 1 de 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: paso 3, imagen 1 de 2 Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: paso 3, imagen 2 de 2
    • Unscrew the other 4, #8 11.5 mm Phillips head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Speaker Replacement, Positioning device: paso 4, imagen 1 de 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: paso 5, imagen 1 de 2 Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: paso 5, imagen 2 de 2
    • Remove the 2, #8 11.7 mm speaker guard screws with the Phillips Head screw driver.
  6. Justin Bieber Concert Microphone Speaker Replacement, Replacing speaker: paso 6, imagen 1 de 1
    • Disconnect the speaker wires from the speaker and replace it with the new one
    • Refer to this guide for help with soldering the wires back onto the speaker.
Conclusión
Mike Seyman
Miembro Desde 10/19/14
437 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-1, Williams Fall 2014 Miembro de Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 189
