Saltar al contenido principal
Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement
Qué necesitas
  1. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: paso 1, imagen 1 de 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing batteries: paso 2, imagen 1 de 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: paso 3, imagen 1 de 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: paso 3, imagen 2 de 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Positioning device: paso 4, imagen 1 de 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Inspecting PCB: paso 5, imagen 1 de 1
    • Inspect the printed circuit board for any breaks or cracks.
  6. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: paso 6, imagen 1 de 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: paso 6, imagen 2 de 2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  7. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: paso 7, imagen 1 de 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: paso 7, imagen 2 de 2
    • Disconnect all wires from the PCB
    • Remove the damaged PCB from the microphone
    • Place new PCB in the Justin Bieber Concert Microphone.
    • Connect all the wires to the new PCB using this soldering guide.
Conclusión
Mike Seyman
Miembro Desde 10/19/14
437 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-1, Williams Fall 2014 Miembro de Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 299
