Saltar al contenido principal
Justin Bieber Concert Microphone On/Off Switch Replacement
Qué necesitas
  1. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: paso 1, imagen 1 de 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back panel: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing batteries: paso 2, imagen 1 de 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: paso 3, imagen 1 de 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing back half of device: paso 3, imagen 2 de 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone On/Off Switch Replacement, Positioning device: paso 4, imagen 1 de 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: paso 5, imagen 1 de 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing PCB: paso 5, imagen 2 de 2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  6. Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: paso 6, imagen 1 de 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Removing on/off switch: paso 6, imagen 2 de 2
    • Remove the 2, #8 11.7 mm Phillips Head screws on the On/Off Switch Board
  7. Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: paso 7, imagen 1 de 2 Justin Bieber Concert Microphone On/Off Switch Replacement, Replacing on/off switch: paso 7, imagen 2 de 2
    • Remove On/Off Switch Board from its holding and detach the wires.
    • Replace the On/Off Switch Board with a new one and reattach the wires using this soldering guide
Conclusión
Mike Seyman
Miembro Desde 10/19/14
437 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-1, Williams Fall 2014 Miembro de Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 164
