Saltar al contenido principal
Justin Bieber Concert Microphone Button Replacement
Qué necesitas
  1. Justin Bieber Concert Microphone Button Replacement, Removing back panel: paso 1, imagen 1 de 2 Justin Bieber Concert Microphone Button Replacement, Removing back panel: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Button Replacement, Removing batteries: paso 2, imagen 1 de 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Button Replacement, Removing back half of device: paso 3, imagen 1 de 2 Justin Bieber Concert Microphone Button Replacement, Removing back half of device: paso 3, imagen 2 de 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Button Replacement, Positioning device: paso 4, imagen 1 de 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Button Replacement, Removing buttons: paso 5, imagen 1 de 2 Justin Bieber Concert Microphone Button Replacement, Removing buttons: paso 5, imagen 2 de 2
    • Remove the buttons by pushing them out from the front of the device. Clean or replace them as needed and place them back into the appropriate slots.
Conclusión
Mike Seyman
Miembro Desde 10/19/14
437 Reputación
4 Guías creadas
Equipo
Baylor, Team 4-1, Williams Fall 2014 Miembro de Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 141
