Saltar al contenido principal
Jura Drainage valve (2)
Qué necesitas
  1. Jura Drainage valve (2), Jura Drainage valve (2): paso 1, imagen 1 de 3 Jura Drainage valve (2), Jura Drainage valve (2): paso 1, imagen 2 de 3 Jura Drainage valve (2), Jura Drainage valve (2): paso 1, imagen 3 de 3
    • The brewing group has already been removed and disassembled. Now it's time for the drainage valve.
    • There will be many pictures
    • All you need a small flathead screwdriver.
  2. Jura Drainage valve (2): paso 2, imagen 1 de 3 Jura Drainage valve (2): paso 2, imagen 2 de 3 Jura Drainage valve (2): paso 2, imagen 3 de 3
    • Images front and back
  3. Jura Drainage valve (2): paso 3, imagen 1 de 3 Jura Drainage valve (2): paso 3, imagen 2 de 3 Jura Drainage valve (2): paso 3, imagen 3 de 3
    • Pull off the clamp and pull out the inlet hose. At the end there is a seal, it often gets stuck in the drainage valve. Swap them out when reassembling.
  4. Jura Drainage valve (2): paso 4, imagen 1 de 3 Jura Drainage valve (2): paso 4, imagen 2 de 3 Jura Drainage valve (2): paso 4, imagen 3 de 3
    • Pull out the clip on the docking tube
    • Pry out the valve body. Make sure the white cap slides out of its hole.
    • Detach the docking nozzle.
  5. Jura Drainage valve (2): paso 5, imagen 1 de 3 Jura Drainage valve (2): paso 5, imagen 2 de 3 Jura Drainage valve (2): paso 5, imagen 3 de 3
    • Detailed photos.
    • The position of the sealing rings are marked green in picture 3.
    • The sealing ring on the docking socket is marked in red in picture 2. It is especially important. It's a little thinner than the other two.
    • The brackets are marked in red.
  6. Jura Drainage valve (2): paso 6, imagen 1 de 3 Jura Drainage valve (2): paso 6, imagen 2 de 3 Jura Drainage valve (2): paso 6, imagen 3 de 3
    • Here all the parts of the valve.
  7. Jura Drainage valve (2): paso 7, imagen 1 de 1
    • Here is the entire valve in one picture
  8. Jura Drainage valve (2): paso 8, imagen 1 de 3 Jura Drainage valve (2): paso 8, imagen 2 de 3 Jura Drainage valve (2): paso 8, imagen 3 de 3
    • Reassembly
    • When assembling, make sure that the lips of the seals point to the pressure side, i.e. inward, and the flat side outward.
    • When installing, make sure that the pressure hose runs through the slot in the valve carrier.
Conclusión
Follow the steps in reverse order to reassemble your device.
3 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
de en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Schwarzstein
Miembro Desde 07/15/13
2,813 Reputación
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 36
Ultimos 30 días: 181
Todo El Tiempo: 7,679
