Saltar al contenido principal
Jumper EZBook Touchpad Replacement
Qué necesitas
  1. Jumper EZBook Touchpad Replacement, Touchpad: paso 1, imagen 1 de 2 Jumper EZBook Touchpad Replacement, Touchpad: paso 1, imagen 2 de 2
    • Place the laptop so the bottom is facing upwards.
    • Remove the two 8 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the three 5 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the six 4 mm screws on the back of the laptop using a T3 Torx screwdriver.
    • Remove the single 3 mm base screw inside the battery case using a T3 Torx screwdriver.
  2. Jumper EZBook Touchpad Replacement: paso 2, imagen 1 de 3 Jumper EZBook Touchpad Replacement: paso 2, imagen 2 de 3 Jumper EZBook Touchpad Replacement: paso 2, imagen 3 de 3
    • Detach the battery case using the flat end of a spudger.
  3. Jumper EZBook Touchpad Replacement: paso 3, imagen 1 de 3 Jumper EZBook Touchpad Replacement: paso 3, imagen 2 de 3 Jumper EZBook Touchpad Replacement: paso 3, imagen 3 de 3
    • Pry apart the bottom cover of the laptop using the flat end of a spudger.
  4. Jumper EZBook Touchpad Replacement: paso 4, imagen 1 de 3 Jumper EZBook Touchpad Replacement: paso 4, imagen 2 de 3 Jumper EZBook Touchpad Replacement: paso 4, imagen 3 de 3
    • Remove the four 4 mm screws from the battery using a T3 Torx screwdriver.
  5. Jumper EZBook Touchpad Replacement: paso 5, imagen 1 de 3 Jumper EZBook Touchpad Replacement: paso 5, imagen 2 de 3 Jumper EZBook Touchpad Replacement: paso 5, imagen 3 de 3
    • Flip the battery to the opposite side of the touchpad.
  6. Jumper EZBook Touchpad Replacement: paso 6, imagen 1 de 3 Jumper EZBook Touchpad Replacement: paso 6, imagen 2 de 3 Jumper EZBook Touchpad Replacement: paso 6, imagen 3 de 3
    • Detach the tape on the left side of the touchpad shown in the first two images.
    • Use a heat gun or a hair dryer to melt the glue quickly.
  7. Jumper EZBook Touchpad Replacement: paso 7, imagen 1 de 3 Jumper EZBook Touchpad Replacement: paso 7, imagen 2 de 3 Jumper EZBook Touchpad Replacement: paso 7, imagen 3 de 3
    • Detach the tape on the right side of the touchpad shown in all three images.
    • Use a hair dryer or a heat gun to soften the glue.
  8. Jumper EZBook Touchpad Replacement: paso 8, imagen 1 de 3 Jumper EZBook Touchpad Replacement: paso 8, imagen 2 de 3 Jumper EZBook Touchpad Replacement: paso 8, imagen 3 de 3
    • Use a spudger to detach the touchpad from the top case.
    • The touchpad is attached to the top case with glue. Use a hair dryer or a heat gun to soften the glue.
    • Be patient. Step 8 can take up to 8 hours if you work by yourself.
    • Don't aim the heat gun or the hair dryer anywhere other than the top case.
  9. Jumper EZBook Touchpad Replacement: paso 9, imagen 1 de 3 Jumper EZBook Touchpad Replacement: paso 9, imagen 2 de 3 Jumper EZBook Touchpad Replacement: paso 9, imagen 3 de 3
    • Lift the touchpad out of the case.
Conclusión
Zed Chen
Miembro Desde 10/25/22
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 79
Todo El Tiempo: 248
