Saltar al contenido principal
John Frieda JFHA5R Reset and Test Buttons Replacement
Qué necesitas
  1. John Frieda JFHA5R Reset and Test Buttons Replacement, Reset and Test Buttons: paso 1, imagen 1 de 1
    • Make sure the Salon Shape brush is unplugged, and do not use metals once you have pried open the power plug.
    • Unscrew the two screws using a 3.0 mm bit triangle head on the back of the power plug.
  2. John Frieda JFHA5R Reset and Test Buttons Replacement: paso 2, imagen 1 de 1
    • Use the spudger along either side to open up the power plug.
    • As the power plug is opened, the caution sticker on top of the plug will rip.
  3. John Frieda JFHA5R Reset and Test Buttons Replacement: paso 3, imagen 1 de 1
    • Slide slightly up to remove the back cover of the power plug.
  4. John Frieda JFHA5R Reset and Test Buttons Replacement: paso 4, imagen 1 de 1
    • Remove the red reset button by pulling it to the right.
  5. John Frieda JFHA5R Reset and Test Buttons Replacement: paso 5, imagen 1 de 1
    • Pull slightly left then up to remove the yellow test button.
Conclusión
Lindsey Farley
Miembro Desde 11/08/17
113 Reputación
1 Guía escrita
Equipo
IUPUI, Team S5-G1, Baechle Fall 2017 Miembro de IUPUI, Team S5-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G1
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 481
