Introducción
Is a broken jewelry clasp preventing you from wearing your favorite pieces? It is common for clasps to break, but that shouldn't be why you never wear your jewelry again. There's a quick and simple way to replace them.
Qué necesitas
Locate the jump ring, which is the link between the clasp and the chain.
On the jump ring, locate the slit.
If the gap remains, twist the jump ring so that the two ends are not aligned.
Keeping one pair of pliers gripped on the jump ring, use the other pair to gently squeeze the rim of the ring bringing the ends closer together.
Once this is done, return the nose pliers to their original position on either side of the slit and twist until the two ends meet.
Enjoy your newly wearable piece of jewelry! If another clasp breaks, you know exactly how to replace it.
3 personas más completaron esta guía.
