Saltar al contenido principal
Jensen JTA-230 Turntable Platter Replacement
Qué necesitas
  1. Jensen JTA-230 Turntable Platter Replacement, Turntable Platter: paso 1, imagen 1 de 1
    • Remove Cover from record player.
  2. Jensen JTA-230 Turntable Platter Replacement: paso 2, imagen 1 de 1
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Turntable Platter Replacement: paso 3, imagen 1 de 1
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Turntable Platter Replacement: paso 4, imagen 1 de 1
    • Replace rubber plugs
  5. Jensen JTA-230 Turntable Platter Replacement: paso 5, imagen 1 de 1
    • Replace Cover
Conclusión
Robert Wilcox
Miembro Desde 03/04/16
227 Reputación
2 Guías creadas
Equipo
Un comentario
There's an important step missing here in that there is a "C" clip on the center pin that you need to remove. Also, this does not include how to replace the belt onto the motor, which is vital in restoring how a record player functions. Can you please update with this information?
ironman175 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 1,648
