Saltar al contenido principal
Jensen JTA-230 Speaker Replacement
Qué necesitas
    • First, open the dust cover and grab it by the hinges and pull up until it slides out.
    • Then, using a screwdriver unscrew the 3 screws on each side and remove the top layer of the record player. The top should pop out.
  1. Jensen JTA-230 Speaker Replacement: paso 2, imagen 1 de 2 Jensen JTA-230 Speaker Replacement: paso 2, imagen 2 de 2
    • You should see the speakers(one on both side). From here, you want to unscrew the three screws holding them in place, using the same head as the previous step.
  2. Jensen JTA-230 Speaker Replacement: paso 3, imagen 1 de 1
    • Carefully remove the speakers from the device, being careful not to harm any components of the speaker.
  3. Jensen JTA-230 Speaker Replacement: paso 4, imagen 1 de 1
    • Once the speaker is out of the device, you should use a soldering iron to take off the wires on the current broken speaker, and put them to the new speaker using a soldering iron.
Conclusión
John Roche
Miembro Desde 03/02/16
175 Reputación
1 Guía escrita
Equipo
Un comentario
What type of speakers do I need to buy?
Isaac Bott - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 579
