Saltar al contenido principal
Jensen JTA-230 Motor Replacement
Qué necesitas
  1. Jensen JTA-230 Motor Replacement, Turntable Platter: paso 1, imagen 1 de 1
    • Remove Cover from record player.
  2. Jensen JTA-230 Motor Replacement: paso 2, imagen 1 de 1
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Motor Replacement: paso 3, imagen 1 de 1
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Motor Replacement: paso 4, imagen 1 de 1
    • Replace rubber plugs
  5. Jensen JTA-230 Motor Replacement: paso 5, imagen 1 de 1
    • Replace Cover
  6. Jensen JTA-230 Motor Replacement, Motor: paso 6, imagen 1 de 2 Jensen JTA-230 Motor Replacement, Motor: paso 6, imagen 2 de 2
    • After removal of the turntable platter, 3 small screws can be seen. Remove the 3 screws which hold the motor in place.
    • On both the right and left side, there are 3 screws, remove each of them.
  7. Jensen JTA-230 Motor Replacement: paso 7, imagen 1 de 2 Jensen JTA-230 Motor Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Gently Pull the top off of the sides and flip over to reveal the circuitry.
    • To remove the top entirely, remove each electrical connection with a pair of tweezers. There are 3, each connecting to the speakers.
  8. Jensen JTA-230 Motor Replacement: paso 8, imagen 1 de 1
    • Remove the Motor from the record player
    • Using a soldering iron, remove the motor from the circuitry.
    • Replace motor with new one.
Conclusión
Robert Wilcox
Miembro Desde 03/04/16
227 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 1,959
