Saltar al contenido principal
Jazz UltraTab C855 Camera Replacement
Qué necesitas
  1. Jazz UltraTab C855 Camera Replacement, Back Cover: paso 1, imagen 1 de 1
  2. Jazz UltraTab C855 Camera Replacement: paso 2, imagen 1 de 1
    • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
  3. Jazz UltraTab C855 Camera Replacement, Camera: paso 3, imagen 1 de 1
    • Remove the two screws holding the internal camera in place.
  4. Jazz UltraTab C855 Camera Replacement: paso 4, imagen 1 de 1
    • Carefully remove the tape of the ribbon cables attached to the camera.
  5. Jazz UltraTab C855 Camera Replacement: paso 5, imagen 1 de 1
    • Using a plastic opening tool, lift open the tab that holds the connection between the camera and motherboard in place. The ribbon cable will become detached.
  6. Jazz UltraTab C855 Camera Replacement: paso 6, imagen 1 de 1
    • Finally, detach the camera lenses from the cover by gently pulling them away from the case.
Conclusión
Kyle Haas
Miembro Desde 09/16/15
245 Reputación
1 Guía escrita
Equipo
IUPUI, Team 1-3, Baechle Fall 2015 Miembro de IUPUI, Team 1-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G3
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 136
