Saltar al contenido principal
Jazz UltraTab C1059-HL Speaker Replacement
Qué necesitas
  1. Jazz UltraTab C1059-HL Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Jazz UltraTab C1059-HL Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • Start by removing the back panel.
    • Remove the 4 screws holding the device together: two on the left side, and two on the right side.
    • Using a metal spudger, carefully pry open the case.
    • With the screws gone, the case is held together with clips along the outside edge of the aluminum backplate.
    • Undoing these clips can take a bit of force. Be cautious not to damage the plastic edge of the device.
  2. Jazz UltraTab C1059-HL Speaker Replacement: paso 2, imagen 1 de 1
    • Place the device on the table with the screen-side down.
  3. Jazz UltraTab C1059-HL Speaker Replacement: paso 3, imagen 1 de 1
    • This is the Speaker.
    • Remove the two black screws.
  4. Jazz UltraTab C1059-HL Speaker Replacement: paso 4, imagen 1 de 1
    • Remove black tape from the wires.
    • Keep this tape, you will need it for reassembly.
  5. Jazz UltraTab C1059-HL Speaker Replacement: paso 5, imagen 1 de 1
    • Using a soldering iron, heat up the spot where the speaker wires connect to the mainboard.
    • Remove Speaker wires when the solder liquifies.
    • Remember to make note of where each wire is connected. When reinstalling the speaker, it is important that the wires are reattached to the same spot.
  6. Jazz UltraTab C1059-HL Speaker Replacement: paso 6, imagen 1 de 1
    • Remove the speaker.
    • Replace the speaker by following these steps in reverse.
Conclusión
Una persona más ha completado esta guía.
Tim Poe
Miembro Desde 09/26/15
361 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-3, Wilson Fall 2015 Miembro de IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 93
