Saltar al contenido principal
Jazz UltraTab C1059-HL Battery Replacement
Qué necesitas
  1. Jazz UltraTab C1059-HL Battery Replacement, Battery: paso 1, imagen 1 de 1
    • remove the screws at the four corners of the device.
  2. Jazz UltraTab C1059-HL Battery Replacement: paso 2, imagen 1 de 2 Jazz UltraTab C1059-HL Battery Replacement: paso 2, imagen 2 de 2
    • Use a prying tool to pry the back panel from the tablet chassis. Pry the panel at different locations around the device to separate clips.
  3. Jazz UltraTab C1059-HL Battery Replacement: paso 3, imagen 1 de 1
    • Use a soldering iron to remove power cables from battery. The power cable is shown at the corner of the battery in the picture.
  4. Jazz UltraTab C1059-HL Battery Replacement: paso 4, imagen 1 de 2 Jazz UltraTab C1059-HL Battery Replacement: paso 4, imagen 2 de 2
    • Use a tool to carefully pry battery away from chassis. The battery is attached by an adhesive. Slowly pry battery on the side away from the motherboard.
  5. Jazz UltraTab C1059-HL Battery Replacement: paso 5, imagen 1 de 1
    • You have successfully removed the battery. Put new battery in the same location. Solder the supply wires. Reapply tape in original location.
Conclusión
Austen Shields
Miembro Desde 09/26/15
101 Reputación
1 Guía escrita
Equipo
IUPUI, Team 1-3, Wilson Fall 2015 Miembro de IUPUI, Team 1-3, Wilson Fall 2015
IUPUI-WILSON-F15S1G3
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 591
