1. You can really take this off however you want but here's a pic.
    • You can really take this off however you want but here's a pic.
  2. Using a spudger or similar pry the guard off one side at a time. Using a spudger or similar pry the guard off one side at a time. Using a spudger or similar pry the guard off one side at a time.
    • Using a spudger or similar pry the guard off one side at a time.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Remove the screws for the speaker and the four that are down the holes. It isn't necessary but I removed the d-ring as well.
    • Remove the screws for the speaker and the four that are down the holes.
    • It isn't necessary but I removed the d-ring as well.
  5. Remove the black button spacers. (Note: There are 3 spacers I lost one). Push the white bottom through the hole and slowly wiggle the blue case off. Be careful not to break the speaker cables. Now remove the four screws.
    • Remove the black button spacers. (Note: There are 3 spacers I lost one).
    • Push the white bottom through the hole and slowly wiggle the blue case off. Be careful not to break the speaker cables.
    • Now remove the four screws.
  6. They used black silicone to keep the connectors together so the entire assembly may come off. I suggest making sure you know how the go back together. Carefully using a knife try to split the silicone so the connectors come off easily. Next remove the fours screws holding the board in. (Note:  There is two matching pairs.)
    • They used black silicone to keep the connectors together so the entire assembly may come off. I suggest making sure you know how the go back together.
    • Carefully using a knife try to split the silicone so the connectors come off easily.
    • Next remove the fours screws holding the board in. (Note: There is two matching pairs.)
    • Using the spudger remove the battery from the white plastic.
  7. Yay! It is disassembled. (Note: There are 3 spacers I lost one).
    • Yay! It is disassembled.
    • (Note: There are 3 spacers I lost one).
Conclusión
Wolf Andrew
Miembro Desde 19/03/18
133 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 6
Últimos 30 Días: 9
Todo El Tiempo: 71
