Introducción
The battery will be replaced by dismantling the device, disconnecting the current battery and connecting a new battery.
Qué necesitas
Insert the plastic opening tool underneath the mesh top.
Pry the cover open.
Expose the motherboard and battery and place in a position that will be easy to access and work with.
Use tweezers to remove the battery's wire from the motherboard at the connection point.
Pull the battery from the motherboard.
Una persona más ha completado esta guía.
